Einleitung
This guide will show the user how to replace a cracked, broken, or damaged base panel on the Dell Alienware 13 laptop.
Was du brauchst
Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
Remove the small access panel using a heavy duty spudger.
2 weitere Personen haben diese Anleitung absolviert.
