Zum Hauptinhalt wechseln
Dell Alienware 13 Palm Rest Replacement
Was du brauchst
  1. Dell Alienware 13 Palm Rest Replacement, Base Panel: Schritt 1, Bild 1 von 1
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Palm Rest Replacement: Schritt 2, Bild 1 von 1
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Palm Rest Replacement: Schritt 3, Bild 1 von 3 Dell Alienware 13 Palm Rest Replacement: Schritt 3, Bild 2 von 3 Dell Alienware 13 Palm Rest Replacement: Schritt 3, Bild 3 von 3
    • Remove the small access panel using a heavy duty spudger.
  4. Dell Alienware 13 Palm Rest Replacement, Disconnecting the Keyboard: Schritt 4, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
  5. Dell Alienware 13 Palm Rest Replacement, Removing the Screws: Schritt 5, Bild 1 von 2 Dell Alienware 13 Palm Rest Replacement, Removing the Screws: Schritt 5, Bild 2 von 2
    • Remove the screws that secure the palm-rest assembly to the computer base.
  6. Dell Alienware 13 Palm Rest Replacement, Popping out the Palm-Rest Assembly: Schritt 6, Bild 1 von 1
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
  7. Dell Alienware 13 Palm Rest Replacement, Turn the Computer Over: Schritt 7, Bild 1 von 1
    • Turn the computer over and open the display as far as possible.
  8. Dell Alienware 13 Palm Rest Replacement, Prying the Edges: Schritt 8, Bild 1 von 1
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  9. Dell Alienware 13 Palm Rest Replacement, Lifting the Palm-Rest Assembly: Schritt 9, Bild 1 von 1
    • Gently lift the palm-rest assembly and turn it over.
  10. Dell Alienware 13 Palm Rest Replacement, Disconnecting the Power-Board Cable: Schritt 10, Bild 1 von 2 Dell Alienware 13 Palm Rest Replacement, Disconnecting the Power-Board Cable: Schritt 10, Bild 2 von 2
    • Lift the connector latch and disconnect the power-button board cable from the system board.
    • Remove the Keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
  11. Dell Alienware 13 Palm Rest Replacement, Connecting the Power-Button Board Cable: Schritt 13, Bild 1 von 1
    • Connect the power-button board cable to the system board.
  12. Dell Alienware 13 Palm Rest Replacement, Aligning the Palm-Rest Assembly.: Schritt 14, Bild 1 von 1
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Close the display and turn the computer over.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
Abschluss
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 242
