Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
In this guide, we will show how to remove and replace the Base Cover.
Ersatzteile
Keine Ersatzteile angegeben.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Lift the base cover off the computer base.
    • Lift the base cover off the computer base.
  4. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  5. Using a plastic scribe, disconnect the battery cable from the system board.
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  6. Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  7. Tighten the five captive screws that secure the base cover to the computer base.
    • Tighten the five captive screws that secure the base cover to the computer base.
Abschluss
Terrence15
72.100 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
21 Mitglieder
1.816 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 4
Insgesamt: 297
