Einleitung
This guide will show the user how to replace a broken touch pad that is not functioning properly on a Dell Alienware 13 laptop.
Was du brauchst
Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
Remove the small access panel using a heavy duty spudger.
Remove (4) 6 mm Phillips head screws from the solid-state metal drive bracket, using a Phillips # 1 screwdriver.
Grab the pull tab to pivot the solid-state drive bracket upwards. Remove the bracket from the computer base.
Using the pull tab, disconnect the black solid-state drive cable from the system board.
Remove (2) 3 mm Phillips head screws, using a Phillips # 0 screwdriver, that connect the solid-state drive assembly to the computer base.
Locate two cables labeled, "KB Backlight" (orange) and "KB Membrane" (black). Lift up on the latches to disconnect the cables from the system board.
Remove (8) 9 mm Phillips head screws using a Phillips # 1 screwdriver, that secures the palm-rest assembly to the computer base.
Remove (4) 8 mm Phillips head screws using a Phillips # 1 screwdriver.
Remove (2) 7 mm Phillips head screws using a Phillips # 1 screwdriver.
Lift the computer base slightly towards you and push the release tabs on the palm-rest assembly until it pops out using a spudger.
Turn the computer over and open the display as far as possible.
Using a plastic spudger, pry up along the edges of the palm-rest assembly.
Gently lift the palm-rest assembly.
Lift the connector latch and disconnect the power-button board cable from the system board. Identified as a cable with a blue tab.
Lift the palm-rest assembly off the computer base.
Remove (4) 3 mm Phillips head screws securing the touch pad to the palm rest assembly using a Phillips # 0 screwdriver.
Lift up and remove the touch pad from the palm rest assembly.
