Zum Hauptinhalt wechseln
Einleitung
in this guide, we will be showing you how to remove and replace the Wireless Mini-Card.
Ersatzteile
Keine Ersatzteile angegeben.
  1. WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Remove the screws that secure the base cover to the computer base. Remove the screws that secure the base cover to the computer base.
    • Remove the screws that secure the base cover to the computer base.
  3. Slide and lift the base cover off the computer base.
    • Slide and lift the base cover off the computer base.
  4. Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Replace the screws that secure the base cover to the computer base.
    • Replace the screws that secure the base cover to the computer base.
  6. Turn the computer over and open the display.
    • Turn the computer over and open the display.
  7. WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer.   After working inside your computer, follow the instructions in After Working Inside Your Computer.
  8. Remove the screws that secure the battery to the computer base.
    • Remove the screws that secure the battery to the computer base.
  9. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  10. Using the battery cable, lift the battery and release it from the tabs on the computer base.
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  11. Turn the computer over and open the display as far as possible.
    • Turn the computer over and open the display as far as possible.
  12. Press and hold the power button for five seconds to ground the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  13. Align the tabs on the NEW battery with  the slots on the computer base.
    • Align the tabs on the NEW battery with the slots on the computer base.
  14. Align the screw holes on the battery with  the screw holes on the computer base.
    • Align the screw holes on the battery with the screw holes on the computer base.
  15. Replace the screws that secure the battery to the computer base.
    • Replace the screws that secure the battery to the computer base.
  16. Connect the battery cable to the system-board connector.
    • Connect the battery cable to the system-board connector.
  17. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before Working Inside Your Computer.  After working inside your computer,  follow the instructions in After Working Inside Your Computer. Disconnect the antenna cables  from the wireless mini-card.
  18. Remove the screw that secures the wireless mini-card to the system board.
    • Remove the screw that secures the wireless mini-card to the system board.
  19. Slide and remove the wireless-mini card from the system-board connector. Slide and remove the wireless-mini card from the system-board connector.
    • Slide and remove the wireless-mini card from the system-board connector.
  20. Align the notch on the NEW wireless mini-card with the tab on the system-board  connector.
    • Align the notch on the NEW wireless mini-card with the tab on the system-board connector.
    • CAUTION: Use firm and even pressure to slide the wireless mini-card into place. If you use excessive force, you may damage the connector.
    • CAUTION: The connectors are keyed to ensure correct insertion. If you feel resistance, check the connectors on the wireless mini-card and on the system-board connector, and realign the wireless mini-card.
    • CAUTION: To avoid damage to the wireless mini-card, never place cables under the wireless mini-card.
  21. Insert the wireless mini-card at a 45-degree angle into the system-board connector.
    • Insert the wireless mini-card at a 45-degree angle into the system-board connector.
  22. Press the other end of the wireless mini-card down into the slot on the system board  and replace the screw that secures the wireless mini-card to the system board.
    • Press the other end of the wireless mini-card down into the slot on the system board and replace the screw that secures the wireless mini-card to the system board.
  23. Connect the antenna cables to the connectors on the wireless mini-card.
    • Connect the antenna cables to the connectors on the wireless mini-card.
Abschluss
Terrence15
70.933 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
930 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 33
