Einleitung
in this guide, we will be showing you how to remove and replace the Wireless Mini-Card.
Was du brauchst
Remove the screws that secure the base cover to the computer base.
Slide and lift the base cover off the computer base.
Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
Replace the screws that secure the base cover to the computer base.
Disconnect the battery cable from the system-board connector.
Remove the screws that secure the battery to the computer base.
Using the battery cable, lift the battery and release it from the tabs on the computer base.
Turn the computer over and open the display as far as possible.
Press and hold the power button for five seconds to ground the system board.
Align the tabs on the NEW battery with the slots on the computer base.
Align the screw holes on the battery with the screw holes on the computer base.
Replace the screws that secure the battery to the computer base.
Connect the battery cable to the system-board connector.
Disconnect the antenna cables from the wireless mini-card.
Remove the screw that secures the wireless mini-card to the system board.
Slide and remove the wireless-mini card from the system-board connector.
Align the notch on the NEW wireless mini-card with the tab on the system-board connector.
Insert the wireless mini-card at a 45-degree angle into the system-board connector.
Press the other end of the wireless mini-card down into the slot on the system board and replace the screw that secures the wireless mini-card to the system board.
Connect the antenna cables to the connectors on the wireless mini-card.
