Zum Hauptinhalt wechseln
Dell Alienware 15 R3 Battery Replacement
Was du brauchst
  1. Dell Alienware 15 R3 Battery Replacement, Back Case: Schritt 1, Bild 1 von 3 Dell Alienware 15 R3 Battery Replacement, Back Case: Schritt 1, Bild 2 von 3 Dell Alienware 15 R3 Battery Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Alienware 15 R3 Battery Replacement: Schritt 4, Bild 2 von 2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Battery Replacement: Schritt 5, Bild 1 von 3 Dell Alienware 15 R3 Battery Replacement: Schritt 5, Bild 2 von 3 Dell Alienware 15 R3 Battery Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
  6. Dell Alienware 15 R3 Battery Replacement, Battery: Schritt 6, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
  7. Dell Alienware 15 R3 Battery Replacement: Schritt 7, Bild 1 von 3 Dell Alienware 15 R3 Battery Replacement: Schritt 7, Bild 2 von 3 Dell Alienware 15 R3 Battery Replacement: Schritt 7, Bild 3 von 3
    • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
    • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Jake Nelson
642 Reputation
7 Anleitungen geschrieben
2 Kommentare zur Anleitung
does not seem to be for my alienware r3 15 inch
Craig Anderson - Antwort Teilen
step 5 - you need to unscrew 10 screws, not 9. You missed the one in the center.
Mike Kravchenko - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 28
Letzte 30 Tage: 119
Insgesamt: 9,673
