Zum Hauptinhalt wechseln
Dell Alienware 15 R3 Cover Assembly Replacement
Was du brauchst
  1. Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: Schritt 1, Bild 1 von 3 Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: Schritt 1, Bild 2 von 3 Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Cover Assembly Replacement: Schritt 2, Bild 1 von 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Cover Assembly Replacement, Cover Assembly: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Cover Assembly Replacement: Schritt 4, Bild 1 von 2 Dell Alienware 15 R3 Cover Assembly Replacement: Schritt 4, Bild 2 von 2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Cover Assembly Replacement: Schritt 5, Bild 1 von 3 Dell Alienware 15 R3 Cover Assembly Replacement: Schritt 5, Bild 2 von 3 Dell Alienware 15 R3 Cover Assembly Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
Abschluss
Jake Nelson
581 Reputation
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 26
Insgesamt: 418
