Zum Hauptinhalt wechseln
Dell Alienware 15 R3 RAM Replacement
Was du brauchst
  1. Dell Alienware 15 R3 RAM Replacement, Back Case: Schritt 1, Bild 1 von 3 Dell Alienware 15 R3 RAM Replacement, Back Case: Schritt 1, Bild 2 von 3 Dell Alienware 15 R3 RAM Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 RAM Replacement: Schritt 2, Bild 1 von 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • To remove the old RAM sticks, push the metal arms out to the side, using an opening tool or your fingers.
    • Slide the RAM stick out at a 45 degree angle.
    • The RAM sticks are not pictured in this device.
    • To place the new RAM stick, insert it at a 45 degree angle and push it down gently. The metal sides will latch if they are in the correct position.
Abschluss
Jake Nelson
642 Reputation
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 660
