Zum Hauptinhalt wechseln
Dell Alienware 15 R3 Wi-Fi Card Replacement
Was du brauchst
    1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: Schritt 1, Bild 1 von 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: Schritt 1, Bild 2 von 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: Schritt 1, Bild 3 von 3
      • Before you begin, turn off the laptop and unplug the charger.
      • Flip the laptop over so that the backside is facing up.
      • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
      • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
      Frag FixBot
      Kommentar hinzufügen
    2. Dell Alienware 15 R3 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 1
      • Use the opening tool to pry the back case from the computer.
      • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
      • Start from the black vent for an easier removal.
      • Lift the back case off of the laptop.
      Frag FixBot
    1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Cover Assembly: Schritt 3, Bild 1 von 1
      • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
      Frag FixBot
    2. Dell Alienware 15 R3 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 Dell Alienware 15 R3 Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
      • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
      Frag FixBot
    3. Dell Alienware 15 R3 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 3 Dell Alienware 15 R3 Wi-Fi Card Replacement: Schritt 5, Bild 2 von 3 Dell Alienware 15 R3 Wi-Fi Card Replacement: Schritt 5, Bild 3 von 3
      • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
      • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
      Frag FixBot
    1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 6, Bild 1 von 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 6, Bild 2 von 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 6, Bild 3 von 3
      • Open the flap to reveal the Wi-Fi card.
      • Use the Phillips #00 screwdriver to remove the screw securing the Wi-Fi card.
      • Use a spudger to detach the coaxial cables from the Wi-Fi card.
      • Be careful when detaching these cable connectors from the Wi-Fi card. The base of the connectors are prone to break off.
      Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 43
Insgesamt: 970
