Zum Hauptinhalt wechseln
Dell Alienware 17 Base cover Replacement
Was du brauchst
  1. Dell Alienware 17 Base cover Replacement, turning the computer over: Schritt 1, Bild 1 von 1
  2. Dell Alienware 17 Base cover Replacement, removing screws: Schritt 2, Bild 1 von 1
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 17 Base cover Replacement, slide base cover: Schritt 3, Bild 1 von 1
    • Slide the base cover toward the front of the computer.
  4. Dell Alienware 17 Base cover Replacement, remove the base cover: Schritt 4, Bild 1 von 1
    • Lift the base cover off.
  5. Dell Alienware 17 Base cover Replacement, replacing base cover: Schritt 5, Bild 1 von 1
    • Align the tabs on the new base cover with the slots on the computer base
  6. Dell Alienware 17 Base cover Replacement, placing screw: Schritt 6, Bild 1 von 1
    • Slide the base cover toward the back of the computer and align the screws holes on the base cover with the screw holes on the computer base.
  7. Dell Alienware 17 Base cover Replacement, secure base cover: Schritt 7, Bild 1 von 1
    • Replace the screws that secure the base cover to the computer base.
Abschluss
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 17
Insgesamt: 909
