Einleitung
In this guide, we will show you how to remove and replace Memory Modules 1 & 2.
Was du brauchst
Remove the screws that secure the base cover to the computer base.
Align the tabs on the new base cover with the slots on the computer base
Slide the base cover toward the back of the computer and align the screws holes on the base cover with the screw holes on the computer base.
Replace the screws that secure the base cover to the computer base.
Disconnect the battery cable from the system board.
Remove the screws that secure the battery to the computer base.
Using the battery cable, lift and release the battery from the tabs on the computer base.
Press and hold the power button for five seconds to ground the system board.
Slide the NEW battery under the tabs on the computer base.
Align the screw holes on the battery with the screw holes on the computer base.
Replace the screws that secure the battery to the computer base.
Remove the screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, lift the hard-drive assembly off the computer base.
Remove the screws that secure the hard-drive bracket to the hard drive.
Lift the hard-drive bracket off the hard drive.
Replace the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
Place the hard-drive assembly in the hard-drive bay.
Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
Replace the screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, gently lift the hard-drive assembly.
Lift the latch and disconnect the hard-drive cable from the system board.
Lift the hard-drive assembly off the computer base.
Using your fingertips, carefully spread apart the securing clips at the sides of the memory-module connector until the memory module pops up.
Slide and remove the memory module from the memory-module connector.
Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module into the connect or at a 45-degree angle, and press the memory module down until it clicks in place. If you do not hear the click, remove and reinstall the memory module
