Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
In this guide, we will be showing you how to remove and replace the Coin-Cell Battery.
Ersatzteile
Keine Ersatzteile angegeben.
  1. WARNING:   Before working inside your computer, read the safety information that shipped with your  computer and follow the steps in Before     You     Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Use a Phillips screwdriver to remove the three screws securing the base cover.
    • Use a Phillips screwdriver to remove the three screws securing the base cover.
  3. Slide the base cover towards the rear of  the computer and lift it off the computer  base.
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. WARNING: Before working inside your computer, read the safety  information that shipped with your  computer and follow the steps in Before You Begin.
    • WARNING: The battery may explode if installed incorrectly. Replace the battery only with the same or equivalent type. Discard used batteries according to the manufacturer’s instructions.
    • CAUTION: Removing the coin-cell battery resets the BIOS settings to default. It is recommended that you note the BIOS settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from its connector on the system board.
  5. Remove the coin-cell battery cable from the routing guides on the computer base.
    • Remove the coin-cell battery cable from the routing guides on the computer base.
  6. Pry up the coin-cell battery from  the slot on the system board.
    • Pry up the coin-cell battery from the slot on the system board.
  7. Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer  base.
    • Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer base.
  8. Route the coin-cell battery cable through the routing guides on the computer base.
    • Route the coin-cell battery cable through the routing guides on the computer base.
  9. Connect the coin-cell battery cable to  its connector on the system board.
    • Connect the coin-cell battery cable to its connector on the system board.
Ziellinie
Ein weiterer Nutzer hat diese Anleitung absolviert.
darrius
5.102 Reputation
30 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
32 Mitglieder
1.933 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 160
