Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ersatzteile
Keine Ersatzteile angegeben.
  1. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Disconnect the hard-drive cable from its connector on the system board.
  2. Loosen the captive screws that secure the hard-drive assembly to the computer base.
    • Loosen the captive screws that secure the hard-drive assembly to the computer base.
  3. Using the pull-tab, lift the hard-drive  assembly out of the computer base.
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Disconnect the interposer from the hard drives. NOTE: Your computer supports up to three drives.
    • Disconnect the interposer from the hard drives.
    • NOTE: Your computer supports up to three drives.
  5. Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
    • Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
  6. Place the NEW primary hard drive  in the hard-drive bracket.
    • Place the NEW primary hard drive in the hard-drive bracket.
  7. If applicable, slide the secondary hard drive into the hard-drive bracket.
    • If applicable, slide the secondary hard drive into the hard-drive bracket.
  8. Replace the screws that secure the primary hard drive to the hard-drive bracket.
    • Replace the screws that secure the primary hard drive to the hard-drive bracket.
  9. If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
    • If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
  10. Connect the interposer to the hard drives.
    • Connect the interposer to the hard drives.
  11. Place the hard-drive assembly in the computer base.
    • Place the hard-drive assembly in the computer base.
  12. Tighten the captive screws that secure  the hard-drive assembly to the computer  base.
    • Tighten the captive screws that secure the hard-drive assembly to the computer base.
  13. Connect the hard-drive cable to its connector on the system board.
    • Connect the hard-drive cable to its connector on the system board.
Ziellinie
2 weitere Nutzer haben diese Anleitung absolviert.
darrius
5.102 Reputation
30 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
32 Mitglieder
1.933 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 236
