Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
In this guide, we will be showing you how to remove and replace the Memory Module.
Ersatzteile
Keine Ersatzteile angegeben.
  1. WARNING:   Before working inside your computer, read the safety information that shipped with your  computer and follow the steps in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. To remove memory module(s) from connectors DIMM3 and DIMM4, go to step 3.
    • To remove memory module(s) from connectors DIMM3 and DIMM4, go to step 3.
    • To remove memory module(s) from connectors DIMM1 and DIMM2: Remove the palm rest. See"Removing the Palm Rest" on page 39.
  3. CAUTION:  To prevent damage to the memory-module connector, do  not use tools to spread the memory module securing clips.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  4. Remove the memory module from the memory-module connector.
    • Remove the memory module from the memory-module connector.
  5. Align the notch on the NEW memory module with the tab on the memory-module connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  6. Slide the memory module firmly into the connector at a 45-degree angle and press  the memory module down until it clicks into place. If you do not hear the click,  remove the memory module and reinstall it.
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Ziellinie
2 weitere Nutzer haben diese Anleitung absolviert.
darrius
5.102 Reputation
30 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
32 Mitglieder
1.933 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 136
