Einleitung
This guide provides a concise, step-by-step process for replacing the battery in your Dell Alienware M11x R3 gaming laptop. Replacing the battery can help extend your laptop's life and improve your gaming experience. Before starting, gather the required tools and a compatible replacement battery, and remember to work on a clean, static-free surface while handling internal components carefully.
Was du brauchst
Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
Remove the bottom cover from the laptop.
Ensure your Dell Alienware M11x R3 is turned off and disconnected from any power source. Close the lid and flip the laptop over to access the bottom panel.
Close the lid and flip the laptop over to access the bottom panel. Unscrew the two circled screws.
After removing the two screws, gently lift up the battery with the small plastic tab attached.
With the wire unplugged, and all of the screws taken out, you are free to remove the battery for replacement.
To reassemble your device, follow these instructions in reverse order using a new battery in place of the old one.
2 weitere Personen haben diese Anleitung absolviert.
