Einleitung
In this guide, we will show you how to remove and replace the Display Assembly.
Was du brauchst
Remove the four screws (two from each hinge) that secure the display assembly to the computer base.
Bend the display assembly towards the computer base at a 45-degree angle and lift the display assembly off the computer.
Align the screw holes on the display hinges with the computer base.
Replace the four screws (two on each hinge) that secure the display assembly to the computer base.
