Zum Hauptinhalt wechseln
Dell Alienware M17x R3 Battery Pack Replacement
Was du brauchst
  1. Dell Alienware M17x R3 Battery Pack Replacement, Turning Over the Computer: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To avoid damage to the computer, use only the battery designed for this particular Alienware computer. Do not use batteries designed for other Alienware computers.
    • Shut down the computer and turn it over.
  2. Dell Alienware M17x R3 Battery Pack Replacement, Popping Out the Battery Pack: Schritt 2, Bild 1 von 2 Dell Alienware M17x R3 Battery Pack Replacement, Popping Out the Battery Pack: Schritt 2, Bild 2 von 2
    • Slide the battery latch to the unlock position as shown. The battery pack pops up.
  3. Dell Alienware M17x R3 Battery Pack Replacement, Removing the Battery Pack: Schritt 3, Bild 1 von 1
    • Remove the battery pack.
  4. Dell Alienware M17x R3 Battery Pack Replacement, Align the Tabs: Schritt 4, Bild 1 von 1
    • Align the tabs on the NEW battery with the slots on the battery bay and snap the battery into place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Terrence15
79.161 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 783
