Einleitung
In this guide, we will show you how to remove and replace the Hard Drive.
Was du brauchst
Loosen the three captive screws that se cure the hard-drive assembly to the computer base.
Using the pull-tab, lift the hard-drive assembly to disconnect it from the connector on the system board.
Lift the hard-drive assembly out of the computer base.
Remove the four screws that secure the hard drive to the hard-drive bracket.
Replace the four screws that secure the hard drive to the hard-drive bracket.
Align the connector on the hard drive with the connector on the system board and press the hard drive until it is fully seated.
Tighten the three captive screws that secure the hard-drive assembly to the computer base.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
