Einleitung
In this guide, we will show you how to remove and replace the Memory Modules.
Was du brauchst
Remove the three screws that secure the memory-module cover to the palm rest assembly.
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector un til the memory module pops up.
Remove the memory module from the memory-module connector.
Align the notch in the NEW memory module with the tab in the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
