Zum Hauptinhalt wechseln
Dell Alienware M17x R3 Memory Modules Replacement
Was du brauchst
  1. Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Modules: Schritt 1, Bild 1 von 2 Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Modules: Schritt 1, Bild 2 von 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Remove the three screws that secure the memory-module cover to the palm rest assembly.
  2. Dell Alienware M17x R3 Memory Modules Replacement, Spreading Apart the Clips: Schritt 2, Bild 1 von 3 Dell Alienware M17x R3 Memory Modules Replacement, Spreading Apart the Clips: Schritt 2, Bild 2 von 3 Dell Alienware M17x R3 Memory Modules Replacement, Spreading Apart the Clips: Schritt 2, Bild 3 von 3
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector un til the memory module pops up.
  3. Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Module: Schritt 3, Bild 1 von 2 Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Module: Schritt 3, Bild 2 von 2
    • Remove the memory module from the memory-module connector.
  4. Dell Alienware M17x R3 Memory Modules Replacement, Align the Notch: Schritt 4, Bild 1 von 1
    • If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  5. Dell Alienware M17x R3 Memory Modules Replacement, Installing the Memory Module: Schritt 5, Bild 1 von 1
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Abschluss
Terrence15
79.161 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 516
