Zum Hauptinhalt wechseln
Dell Alienware M18x R2 Hard Drive Replacement
Was du brauchst
  1. Dell Alienware M18x R2 Hard Drive Replacement, Lifting the Connector Latch: Schritt 1, Bild 1 von 2 Dell Alienware M18x R2 Hard Drive Replacement, Lifting the Connector Latch: Schritt 1, Bild 2 von 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive
    • Lift the connector latch that secures the hard-drive cable to the connector on the system board, and then disconnect the hard-drive cable from the connector on the system board.
  2. Dell Alienware M18x R2 Hard Drive Replacement, Lifting the Hard-Drive Assembly: Schritt 2, Bild 1 von 1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  3. Dell Alienware M18x R2 Hard Drive Replacement, Disconnecting the Interposer: Schritt 3, Bild 1 von 2 Dell Alienware M18x R2 Hard Drive Replacement, Disconnecting the Interposer: Schritt 3, Bild 2 von 2
    • Disconnect the interposer from the hard drives.
  4. Dell Alienware M18x R2 Hard Drive Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the hard drive(s) and slide the hard drive(s) out of the hard-drive bracket.
  5. Dell Alienware M18x R2 Hard Drive Replacement, Placing the Hard Drive: Schritt 5, Bild 1 von 1
    • Place the NEW primary hard drive (HDD 0) in the hard-drive bracket.
  6. Dell Alienware M18x R2 Hard Drive Replacement, Sliding the Hard Drives: Schritt 6, Bild 1 von 1
    • If applicable, slide the secondary and tertiary hard drive(s) into the hard-drive bracket.
  7. Dell Alienware M18x R2 Hard Drive Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the screws that secure the primary hard drive (HDD 0).
  8. Dell Alienware M18x R2 Hard Drive Replacement, Connecting the Interposer: Schritt 8, Bild 1 von 1
    • If applicable, replace the screws that secure the secondary hard drive (HDD 1) and tertiary hard drive (HDD 2) to the hard-drive bracket.
    • Connect the interposer to the hard drive(s).
  9. Dell Alienware M18x R2 Hard Drive Replacement, Placing the Hard-Drive Assembly: Schritt 9, Bild 1 von 1
    • Place the hard-drive assembly in the computer base.
  10. Dell Alienware M18x R2 Hard Drive Replacement, Tighten the Captive Screws: Schritt 10, Bild 1 von 1
    • Tighten the captive screws that secure the hard-drive assembly to the computer base.
  11. Dell Alienware M18x R2 Hard Drive Replacement, Sliding the Hard-Drive Cable: Schritt 11, Bild 1 von 1
    • Slide the hard-drive cable into the connector on the system board and press down on the connector latch to secure the cable.
Abschluss
Terrence15
79.309 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.984 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 1,061
