Zum Hauptinhalt wechseln
Dell Chromebook 11 3180 Motherboard Replacement
Was du brauchst
  1. Dell Chromebook 11 3180 Motherboard  Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 4, Bild 1 von 1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 5, Bild 1 von 1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Motherboard  Replacement, Battery: Schritt 6, Bild 1 von 2 Dell Chromebook 11 3180 Motherboard  Replacement, Battery: Schritt 6, Bild 2 von 2
    • Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
    • You can locate this cable by checking that its other end connects to the battery. It has black protective wrap.
  7. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 7, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove each of the three 3mm screws from the battery.
  8. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 8, Bild 1 von 1
    • Lift the battery away from the computer to remove it.
    • If there is any resistance to the battery being removed, make sure that all of the screws have been properly removed and that nothing is blocking the battery.
  9. Dell Chromebook 11 3180 Motherboard  Replacement, Motherboard: Schritt 9, Bild 1 von 3 Dell Chromebook 11 3180 Motherboard  Replacement, Motherboard: Schritt 9, Bild 2 von 3 Dell Chromebook 11 3180 Motherboard  Replacement, Motherboard: Schritt 9, Bild 3 von 3
    • Lift the black clasp and gently pull on blue ribbon until it completely disconnects from the motherboard.
  10. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 10, Bild 1 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 10, Bild 2 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 10, Bild 3 von 3
    • Lift the black clasp and use the spudger tool to remove the ribbon so that it completely disconnects from the motherboard.
  11. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 11, Bild 1 von 2 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 11, Bild 2 von 2
  12. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 12, Bild 1 von 2 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 12, Bild 2 von 2
    • Locate and gently pull the wire harness (small plastic box with wires leading to the black audio speakers) directly out of the connector on the motherboard.
  13. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 13, Bild 1 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 13, Bild 2 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 13, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
    • Remove the metal shield protecting the black and white wires beneath it.
  14. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 14, Bild 1 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 14, Bild 2 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 14, Bild 3 von 3
    • Locate and gently pull up on the white and black wires to disconnect them from the motherboard.
  15. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 15, Bild 1 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 15, Bild 2 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 15, Bild 3 von 3
    • Locate and gently pull the wire harness (small plastic box with two pink, one orange, and two black wires) directly out of the connector on the motherboard.
  16. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 16, Bild 1 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 16, Bild 2 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 16, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove the two 3mm screws.
  17. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 17, Bild 1 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 17, Bild 2 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 17, Bild 3 von 3
  18. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 18, Bild 1 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 18, Bild 2 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 18, Bild 3 von 3
    • Lift black clasp and gently pull on the back of the wire until it completely disconnects from the motherboard.
  19. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 19, Bild 1 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 19, Bild 2 von 3 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 19, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove the five 3mm screws.
  20. Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 20, Bild 1 von 2 Dell Chromebook 11 3180 Motherboard  Replacement: Schritt 20, Bild 2 von 2
    • Gently lift and remove the motherboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
George Erie
354 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S22-G1, Livingston Spring 2017 Mitglied von Cal Poly, Team S22-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G1
4 Mitglieder
8 Anleitungen geschrieben
2 Kommentare zur Anleitung
Dell Chromebook 11 3180 3189 uses a very special power jack connector, the power jack is soldering to a iron cover, people have to replace the whole part when the jack is broken/burnt, this is the correct part: https://www.dcincable.com/xnj46-0xnj46-c..., remember not to move the laptop while charging the battery, a good habit can make the laptop working longer.
Tom - Antwort Teilen
On the dell 3180 non Chromebook variant You don't have to remove the hole motherboard just finesse it out and replace the part.
Jacob Hickman - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 72
Insgesamt: 4,770
