Einleitung
This guide demonstrates how to replace the touch pad of your device. The touch pad may become damaged or malfunction after extended use, and replacing it is very straightforward and should not take long.
Ersatzteile
Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
Using a plastic opening tool, begin to separate the back cover from the body of the computer.
Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
Using a Phillips #0 screwdriver, remove each of the three 3mm screws from the battery.
Unplug the touch pad from itself by lifting up on the connector and pull out the ribbon cable.
Using a Phillips #0 screwdriver, remove the five 2mm and single 3mm screws. Set the screws aside and note that they are for the touch pad.
