Zum Hauptinhalt wechseln
Dell Chromebook 11 CB1C13 Battery Replacement
Was du brauchst
  1. Dell Chromebook 11 CB1C13 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Chromebook 11 CB1C13 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery.
  3. Dell Chromebook 11 CB1C13 Battery Replacement: Schritt 3, Bild 1 von 2 Dell Chromebook 11 CB1C13 Battery Replacement: Schritt 3, Bild 2 von 2
    • Use a plastic spudger to push the bundled cable connector free in the same direction as the individual wires are running.
    • You can use your fingers to help pull the cable free. Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Proceed to gently remove the battery from the back panel.
Abschluss
To replace your Dell Chromebook 11 battery, follow these instructions in order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jerry Geffrard
334 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G6, Bailey Fall 2017
UMASSD-BAILEY-F17S3G6
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 1,312
