Zum Hauptinhalt wechseln
Dell Chromebook 11 CB1C13 DC Jack Cable Replacement
Was du brauchst
    • Get your trusty Phillips screwdriver and unscrew the Phillips Screws and put them somewhere safe.
    • Then pry open and remove bottom case cover.
    • Now what you want to do is find two screws protecting the battery. Unscrew them and put them somewhere safe.
    • Remove the cable from the battery and put it somewhere safe.
    • Now, find the DC Jack Cable. It should be in the top right corner.
    • To remove the DC Jack Cable, use your fingernails and try to remove it. Once out, put it somewhere safe.
    • To put in a new one, insert it with a lot of pressure and it should be secure.
Abschluss
To reassemble your device, follow steps 1 and 2 in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
EmreTech
190 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 81
