Zum Hauptinhalt wechseln
Dell Chromebook 11 CB1C13 Screen Cover Replacement
Was du brauchst
  1. Dell Chromebook 11 CB1C13 Screen Cover Replacement, Back Panel: Schritt 1, Bild 1 von 3 Dell Chromebook 11 CB1C13 Screen Cover Replacement, Back Panel: Schritt 1, Bild 2 von 3 Dell Chromebook 11 CB1C13 Screen Cover Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Screen Cover Replacement, Screen Cover: Schritt 2, Bild 1 von 3 Dell Chromebook 11 CB1C13 Screen Cover Replacement, Screen Cover: Schritt 2, Bild 2 von 3 Dell Chromebook 11 CB1C13 Screen Cover Replacement, Screen Cover: Schritt 2, Bild 3 von 3
    • Locate the two hinges on the corners of the device.
    • Unscrew the 5 2mm Phillips #00 screws in the hinges.
    • Pull the hinges up and slide bottom cover out
    • Gently remove the cover since it is still connected to the device by some wires
  3. Dell Chromebook 11 CB1C13 Screen Cover Replacement: Schritt 3, Bild 1 von 2 Dell Chromebook 11 CB1C13 Screen Cover Replacement: Schritt 3, Bild 2 von 2
    • Locate the two cables that connect the top panel to the device. One black, and one white.
    • Remove these two cables by grabbing the golden ends with your fingers, and gently pulling straight up.
    • Remove pin port lifting up the hinge.
  4. Dell Chromebook 11 CB1C13 Screen Cover Replacement: Schritt 4, Bild 1 von 3 Dell Chromebook 11 CB1C13 Screen Cover Replacement: Schritt 4, Bild 2 von 3 Dell Chromebook 11 CB1C13 Screen Cover Replacement: Schritt 4, Bild 3 von 3
    • Locate the seam between the screen cover, and the top panel
    • Starting at one of the hinge corners, take a thin metal prying tool and gently insert it into the seam.
    • Gently push the tool down towards the top panel until you feel the screen cover disconnect.
    • Repeat this process all around the screen cover until it is completely disconnected from the top panel.
    • During this process, you might hear a rough snapping sound. This is normal, and is just the sound of the screen cover's connections to the top panel coming apart.
    • Make sure to be gentle with your prying, and to move in small increments around the screen cover during this process. This is to prevent any cracks or damage to the cover, which could be harmful.
Abschluss
Jerry Geffrard
334 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G6, Bailey Fall 2017
UMASSD-BAILEY-F17S3G6
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 602
