Zum Hauptinhalt wechseln
Dell Chromebook 11-3120 Battery Replacement
Was du brauchst
  1. Dell Chromebook 11-3120 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 2 Dell Chromebook 11-3120 Battery Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
  2. Dell Chromebook 11-3120 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Chromebook 11-3120 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
    • Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
  3. Dell Chromebook 11-3120 Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Dell Chromebook 11-3120 Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
  4. Dell Chromebook 11-3120 Battery Replacement: Schritt 4, Bild 1 von 1
    • Using the pointed end of a #2 spudger, remove the connection between the battery and motherboard by slightly pulling on the wires while pushing the tiny hole down using the spudger.
    • Pull out the battery from inside the laptop.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S4-G1, Julie Fall 2017 Mitglied von UMass Dartmouth, Team S4-G1, Julie Fall 2017
UMASSD-JULIE-F17S4G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 2,657
