Zum Hauptinhalt wechseln
Dell Chromebook 11-3120 Bottom Base Cover Replacement
Was du brauchst
  1. Dell Chromebook 11-3120 Bottom Base Cover Replacement, Remove screws: Schritt 1, Bild 1 von 1
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Bottom Base Cover Replacement: Schritt 2, Bild 1 von 2 Dell Chromebook 11-3120 Bottom Base Cover Replacement: Schritt 2, Bild 2 von 2
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
Abschluss
Dalton D
2.534 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 289
