Einleitung
The USB port allows for small amounts of data to be transferred from computer to computer via a USB drive. Sometimes these drives do not connect properly due to a broken motherboard. Here is a guide on how to properly replace the motherboard.
Was du brauchst
Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
Using the pointed end of a #2 spudger, remove the connection between the battery and motherboard by slightly pulling on the wires while pushing the tiny hole down using the spudger.
Pull out the battery from inside the laptop.
Disconnect the bridge connection ribbon cable from the motherboard.
Using a JIS #0 screwdriver, unscrew the three 4mm screws securing the daughterboard in place.
Carefully lift out the daughterboard with the right-hand USB port from the laptop.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
