Zum Hauptinhalt wechseln
Dell Chromebook 13-7310 Battery Replacement
Was du brauchst
  1. Dell Chromebook 13-7310 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 Dell Chromebook 13-7310 Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Battery Replacement: Schritt 5, Bild 1 von 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
Abschluss
Congratulations! You have successfully removed the battery of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 1,258
