Einleitung
Computer batteries can sometimes become weaker over time, losing charge and making it difficult to properly use your device. If your battery is not functioning correctly anymore, then follow this guide to remove/replace the battery in a Dell Chromebook 13-7310.
Was du brauchst
Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
To remove the battery, lift up on one side to get your fingers underneath and lift away.
Congratulations! You have successfully removed the battery of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
