Zum Hauptinhalt wechseln
Dell Chromebook 13-7310 Cooling Fan Replacement
Was du brauchst
  1. Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: Schritt 1, Bild 1 von 2 Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Cooling Fan Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: Schritt 3, Bild 1 von 2 Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: Schritt 3, Bild 2 von 2
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  4. Dell Chromebook 13-7310 Cooling Fan Replacement: Schritt 4, Bild 1 von 2 Dell Chromebook 13-7310 Cooling Fan Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
Abschluss
Congratulations! You have successfully removed the cooling fan of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 481
