Zum Hauptinhalt wechseln
Dell Chromebook 13-7310 IO Board Replacement
Was du brauchst
  1. Dell Chromebook 13-7310 IO Board Replacement, Back Cover: Schritt 1, Bild 1 von 2 Dell Chromebook 13-7310 IO Board Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 IO Board Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 IO Board Replacement, Battery: Schritt 3, Bild 1 von 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 IO Board Replacement: Schritt 4, Bild 1 von 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 IO Board Replacement: Schritt 5, Bild 1 von 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 IO Board Replacement, IO Board: Schritt 6, Bild 1 von 1
    • Remove the single 2mm screw securing the IO board to the laptop.
  7. Dell Chromebook 13-7310 IO Board Replacement: Schritt 7, Bild 1 von 1
    • Pull up on the connector to release the IO board cable from the motherboard.
    • It may be easier to pull from the blue tab.
  8. Dell Chromebook 13-7310 IO Board Replacement: Schritt 8, Bild 1 von 1
    • Remove the IO board.
Abschluss
Damon
181 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 Mitglied von UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 329
