Einleitung
Having trouble with your headphones or USB ports? The Input/output board may be the source of your problem. Here is a quick an easy guide to replace your IO board, and get your devices working again!
Was du brauchst
Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
To remove the battery, lift up on one side to get your fingers underneath and lift away.
