Einleitung
This guide will tell you step-by-step how to replace the keypad in the Dell Chromebook 3100 2-in-1.
Before beginning, make sure to power off your phone completely and disconnect from any external power source.
Was du brauchst
Using a phillips screw driver (PH1) remove the 9 (M2.5x4) screws holding the back cover
Slide the black clips towards the battery to release the ribbon. Lift the ribbon out and unplug the keyboard cable.
Turn the device over. Then, using a jimmy, firmly press between the keyboard and the laptop frame.
Repeat this process along both sides of the laptop and the bottom of the keyboard.
Once the three sides have been pried open, lift the keyboard slightly and pull towards you.
