Einleitung
Follow this guide to remove and replace the battery in the Dell Chromebook 3110.
For safety, discharge your battery below 25% before disassembling it. This reduces the risk of a dangerous event if the battery is accidentally damaged during the repair.
Was du brauchst
Remove nine 4 mm screws from the back cover of the laptop using a Phillips #00 screwdriver.
Using an opening pick and a plastic opening tool, begin to separate the back cover from the laptop.
Using your hands, fully remove the back cover.
Unplug the battery from the motherboard by gently pulling on the cable header from the motherboard toward the battery.
Using the Phillips #0 screwdriver, remove the three screws from the battery.
Eine weitere Person hat diese Anleitung absolviert.
