Zum Hauptinhalt wechseln
Dell DJ Disassembly
Was du brauchst
  1. Dell DJ Disassembly, Dell DJ Disassembly: Schritt 1, Bild 1 von 3 Dell DJ Disassembly, Dell DJ Disassembly: Schritt 1, Bild 2 von 3 Dell DJ Disassembly, Dell DJ Disassembly: Schritt 1, Bild 3 von 3
    • Inspect your device and be sure that it matches the device that this guide is disassembling.
    • Familiarize yourself with the specific design of the device.
    • Battery replacement is the only repair that our guide offers that does not require a complete tear down.
  2. Dell DJ Disassembly: Schritt 2, Bild 1 von 3 Dell DJ Disassembly: Schritt 2, Bild 2 von 3 Dell DJ Disassembly: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Remove the bottom panel with the metal spudger. This panel may be fused to the outer shell with a dot of adhesive.
    • Four screws fasten a metal plate to the device. Using the device magnetic mat and 54 bit (Phillips J000) driver, remove the screws.
    • Be sure to keep the 4mm screws together and organized on the device magnet plate.
  3. Dell DJ Disassembly: Schritt 3, Bild 1 von 3 Dell DJ Disassembly: Schritt 3, Bild 2 von 3 Dell DJ Disassembly: Schritt 3, Bild 3 von 3
    • The top plate of the device is attached by a dot of glue. Use the metal spudger to pry the plate off.
    • After the top plate is removed, remove the four 4mm screws that attach the inner plate.
    • When the plate is removed, the motherboard will be ready to be removed.
  4. Dell DJ Disassembly: Schritt 4, Bild 1 von 3 Dell DJ Disassembly: Schritt 4, Bild 2 von 3 Dell DJ Disassembly: Schritt 4, Bild 3 von 3
    • Slide the motherboard out of the protective case.
    • Be careful not to snag any wires.
    • When the motherboard is exposed the device is ready to be inspected and repaired.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2016 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Spring 2016
USFSM-STEWART-S16S1G1
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
How did you get the logic board to slide past the scroll wheel ?
kf4qic - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 603
