Einleitung
Use this guide to replace the optical drive in your Dell Dimension 4600.
Was du brauchst
Using your index finger, slide and hold the cover latch down.
While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
Grab the edge of the panel and slide it away from the case until it is removed.
Press and hold the three levers located behind the front panel.
While holding the levers down, swing open the front panel.
Grasp the end of the Drive 1 cable connected to the motherboard and firmly pull upwards until it is removed.
Locate the end of the Drive 1 cable connected to the optical drive.
Grasp the cable and pull firmly to disconnect it from the optical drive.
Locate the screw on the optical drive.
Remove the 7.7 mm screw by using a Phillips #2 screw-driver.
13 weitere Personen haben diese Anleitung absolviert.
