Zum Hauptinhalt wechseln
Dell Dimension 4600 RAM Replacement
Was du brauchst
  1. Dell Dimension 4600 RAM Replacement, Side Panel: Schritt 1, Bild 1 von 1
    • Locate the case cover latch on the back of the computer.
    Frag FixBot
  2. Dell Dimension 4600 RAM Replacement: Schritt 2, Bild 1 von 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
    Frag FixBot
  3. Dell Dimension 4600 RAM Replacement: Schritt 3, Bild 1 von 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
    Frag FixBot
  4. Dell Dimension 4600 RAM Replacement, RAM: Schritt 4, Bild 1 von 1
    • Lay the computer flat on its side so that you are looking down on all of the components.
    • Locate the RAM modules on the motherboard.
    Frag FixBot
  5. Dell Dimension 4600 RAM Replacement: Schritt 5, Bild 1 von 2 Dell Dimension 4600 RAM Replacement: Schritt 5, Bild 2 von 2
    • Locate the white or black tabs holding the RAM module in place.
    • Place your index finger on the tab and firmly press down. The tab should release and the RAM module should be slightly raised.
    • Repeat this for the tab on the other side of the RAM module.
    • Repeat this step for each RAM module.
    Frag FixBot
  6. Dell Dimension 4600 RAM Replacement: Schritt 6, Bild 1 von 2 Dell Dimension 4600 RAM Replacement: Schritt 6, Bild 2 von 2
    • Grasp the RAM module and firmly pull upwards until it is released from its slot.
    Frag FixBot
Abschluss
13 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 6-10, Regan Fall 2011 Mitglied von Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Mitglieder
11 Anleitungen geschrieben
1 Kommentar zur Anleitung
Would be great if the DIMM slots were explained (numbering) as to which are populated for dual channel, etc.
MJfromMD - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 64
Insgesamt: 10,694
