Einleitung
Use this guide to replace the sound card in your computer.
Was du brauchst
Using your index finger, slide and hold the cover latch down.
While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
Grab the edge of the panel and slide it away from the case until it is removed.
Locate the Sound Card and the screw attached to the Sound Card as shown in the picture.
Locate and remove the white connector on the sound card by pulling on the black cable.
6 weitere Personen haben diese Anleitung absolviert.
