Einleitung
Use this guide to replace the video card in your computer.
Was du brauchst
Using your index finger, slide and hold the cover latch down.
While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
Grab the edge of the panel and slide it away from the case until it is removed.
Locate the Video Card and the screw attached to the Video Card as shown in the picture.
Push down on the green clip located by the bottom right corner of the video card while simultaneously pulling the card up with your other hand.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
I have a question - My dell dimension 4600 has lines going down the screen, ive tried 3 different monitors, reinstalling windows (reinstalling would have lines going down the screen, after installing all programs the system freezes up with lines going down the screen nothing else) ive tried system restore can someone tell me whats going on?
That sounds like either a GPU failure or internal Graphics failure. Have you checked thermal paste?
