Zum Hauptinhalt wechseln
Dell Inpiron 3542 Motherboard Replacement
Was du brauchst
  1. Dell Inpiron 3542 Motherboard  Replacement, Motherboard: Schritt 1, Bild 1 von 2 Dell Inpiron 3542 Motherboard  Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Slide the latches on both sides of the laptop outward to unlock the battery.
    • Remove the battery from the computer.
    • Replacing a motherboard can lead to data loss. Make sure to backup any important data on the laptop before replacing the motherboard.
  2. Dell Inpiron 3542 Motherboard  Replacement: Schritt 2, Bild 1 von 2 Dell Inpiron 3542 Motherboard  Replacement: Schritt 2, Bild 2 von 2
    • Remove the screw. (1 x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inpiron 3542 Motherboard  Replacement: Schritt 3, Bild 1 von 3 Dell Inpiron 3542 Motherboard  Replacement: Schritt 3, Bild 2 von 3 Dell Inpiron 3542 Motherboard  Replacement: Schritt 3, Bild 3 von 3
    • Move the hard drive to the open area and remove it.
  4. Dell Inpiron 3542 Motherboard  Replacement: Schritt 4, Bild 1 von 3 Dell Inpiron 3542 Motherboard  Replacement: Schritt 4, Bild 2 von 3 Dell Inpiron 3542 Motherboard  Replacement: Schritt 4, Bild 3 von 3
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the wireless card from the laptop.
  5. Dell Inpiron 3542 Motherboard  Replacement: Schritt 5, Bild 1 von 2 Dell Inpiron 3542 Motherboard  Replacement: Schritt 5, Bild 2 von 2
    • Remove all screws from the bottom of the laptop. (10 x M2.5 x 5mm)
    • Turn over the laptop and open it.
  6. Dell Inpiron 3542 Motherboard  Replacement: Schritt 6, Bild 1 von 2 Dell Inpiron 3542 Motherboard  Replacement: Schritt 6, Bild 2 von 2
    • Use the plastic prying device to release the keyboard. Avoid from using excessive force to prevent damages.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
  7. Dell Inpiron 3542 Motherboard  Replacement: Schritt 7, Bild 1 von 3 Dell Inpiron 3542 Motherboard  Replacement: Schritt 7, Bild 2 von 3 Dell Inpiron 3542 Motherboard  Replacement: Schritt 7, Bild 3 von 3
    • Unplug the touch pad cables located on the palm rest.
    • Remove the screws. (3 x M2.5 x 5mm)
  8. Dell Inpiron 3542 Motherboard  Replacement: Schritt 8, Bild 1 von 2 Dell Inpiron 3542 Motherboard  Replacement: Schritt 8, Bild 2 von 2
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  9. Dell Inpiron 3542 Motherboard  Replacement: Schritt 9, Bild 1 von 1
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  10. Dell Inpiron 3542 Motherboard  Replacement: Schritt 10, Bild 1 von 1
    • Loosen the cables on the antenna.
  11. Dell Inpiron 3542 Motherboard  Replacement: Schritt 11, Bild 1 von 2 Dell Inpiron 3542 Motherboard  Replacement: Schritt 11, Bild 2 von 2
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  12. Dell Inpiron 3542 Motherboard  Replacement: Schritt 12, Bild 1 von 1
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  13. Dell Inpiron 3542 Motherboard  Replacement: Schritt 13, Bild 1 von 2 Dell Inpiron 3542 Motherboard  Replacement: Schritt 13, Bild 2 von 2
    • Unplug the cable on the bottom part of the mother board.
    • Remove the cable on the right side of the motherboard. (3x M2.5 x 5mm)
    • Remove the motherboard from the laptop.
Abschluss
To reassemble your device, follow these instructions in reverse order. Congratulations on replacing the Motherboard on your Dell Inpiron 3542.
5 weitere Personen haben diese Anleitung absolviert.
Rachel lindsey
733 Reputation
5 Anleitungen geschrieben
Texas Tech, Team S46-G1, Bennett Spring 2017 Mitglied von Texas Tech, Team S46-G1, Bennett Spring 2017
TTU-BENNETT-S17S46G1
3 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Anyone know where I can purchase a board for a Dell Inspiron 3542 in the UK?
Darrell Haslam - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 20
Letzte 30 Tage: 32
Insgesamt: 3,749
