Zum Hauptinhalt wechseln
Dell Inspirion 15z-5523 Fan Replacement
Was du brauchst
  1. Dell Inspirion 15z-5523 Fan Replacement, Fan: Schritt 1, Bild 1 von 1
    • First turn over your computer and remove all of the rubber stoppers on the back.
  2. Dell Inspirion 15z-5523 Fan Replacement: Schritt 2, Bild 1 von 1
    • Then remove all the screws that were under the rubber stoppers.
  3. Dell Inspirion 15z-5523 Fan Replacement: Schritt 3, Bild 1 von 1
    • Take the screw out of the back plate.
  4. Dell Inspirion 15z-5523 Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove back plate by grabbing and lifting up.
  5. Dell Inspirion 15z-5523 Fan Replacement: Schritt 5, Bild 1 von 1
    • Remove CD port by pulling it straight out.
  6. Dell Inspirion 15z-5523 Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the keyboard.
  7. Dell Inspirion 15z-5523 Fan Replacement: Schritt 7, Bild 1 von 1
    • Take screw out of the surface below the keyboard and remove the top layer of the computer off of the base.
  8. Dell Inspirion 15z-5523 Fan Replacement: Schritt 8, Bild 1 von 1
    • Remove the battery by unscrewing the 5 screws and pull straight out.
  9. Dell Inspirion 15z-5523 Fan Replacement: Schritt 9, Bild 1 von 1
    • Remove the three screws from the hard drive and remove by pulling straight out.
  10. Dell Inspirion 15z-5523 Fan Replacement: Schritt 10, Bild 1 von 2 Dell Inspirion 15z-5523 Fan Replacement: Schritt 10, Bild 2 von 2
    • Unscrew motherboard and remove the two clips.
  11. Dell Inspirion 15z-5523 Fan Replacement: Schritt 11, Bild 1 von 2 Dell Inspirion 15z-5523 Fan Replacement: Schritt 11, Bild 2 von 2
    • Flip motherboard up, unscrew the three screws, and unclip the fan.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 812
