Zum Hauptinhalt wechseln
  1. Pop out the rubber pieces and unscrew the 7 screws on the bottom of the computer.
    • Pop out the rubber pieces and unscrew the 7 screws on the bottom of the computer.
    • Open the RAM door in the center remove the hidden screw labeled "KB" just above the RAM sticks.
  2. Take off the keyboard.
    • Take off the keyboard.
  3. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  4. Unscrew the surface under the keyboard and remove top plate from the base. Unscrew the surface under the keyboard and remove top plate from the base.
    • Unscrew the surface under the keyboard and remove top plate from the base.
  5. Take the battery out by unscrewing the 5 screws and pulling straight off. Take the battery out by unscrewing the 5 screws and pulling straight off.
    • Take the battery out by unscrewing the 5 screws and pulling straight off.
  6. Remove the hard drive.
    • Remove the hard drive.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 54
Insgesamt: 738
