Einleitung
Here I show how to dismantle a client's Dell Inspirion N4050 laptop to replace their damaged hard drive for a new one
Was du brauchst
Check your laptop model
Turn it over to work on the bottom of the laptop
Open the first latch for the battery
Open the second latch in the direction that the arrow is pointing. This requires more effort than the first one.
The battery will come out a little. Finish removing it gently.
Turn the laptop with the keyboard facing up.
Use a flat-blade screwdriver to separate the keyboard from the computer case.
Tilt the keyboard as shown in the image. Do not remove it completely because it is connected to a cable.
Remove the clip that holds the cable to the motherboard.
Remove the cable.
Remove the memory cards by moving the retaining clips in the direction that the arrows are pointing.
CPU
DDR3 RAM memory, 2 slots avaiable
SATA hard disc
Heatsink
DVD unit
Wireless network card
Battery for the internal clock
The hard disc does not have this support to the mother board from the factory. It is only attached by the SATA connector.
Height is 8.5 mm
To reassemble your device, follow these instructions in reverse.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
