Einleitung
It is advised to proceed with caution when carrying out this procedure. Damage to the sensitive electronic components may occur.
Was du brauchst
Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
After removing the screws, remove the back cover using a plastic or metal spudger.
Unscrew the 3.7mm screw that attaches the solid state drive with the Phillips #0 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
