Zum Hauptinhalt wechseln
Dell Inspiron 11 3169 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 11 3169 Display Assembly Replacement, Remove the Screw: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 11 3169 Display Assembly Replacement, Lifting the Display-Cable: Schritt 2, Bild 1 von 1
    • Lift the display-cable bracket off the system board.
  3. Dell Inspiron 11 3169 Display Assembly Replacement, Peeling off the Tape: Schritt 3, Bild 1 von 2 Dell Inspiron 11 3169 Display Assembly Replacement, Peeling off the Tape: Schritt 3, Bild 2 von 2
    • Peel off the tape to access the display cable.
  4. Dell Inspiron 11 3169 Display Assembly Replacement, Open the Latch: Schritt 4, Bild 1 von 1
    • Open the latch and disconnect the display cable.
  5. Dell Inspiron 11 3169 Display Assembly Replacement, Open the Latch: Schritt 5, Bild 1 von 3 Dell Inspiron 11 3169 Display Assembly Replacement, Open the Latch: Schritt 5, Bild 2 von 3 Dell Inspiron 11 3169 Display Assembly Replacement, Open the Latch: Schritt 5, Bild 3 von 3
    • Open the latch and disconnect the sensor-board cable from the I/O board.
  6. Dell Inspiron 11 3169 Display Assembly Replacement, Peeling the Tapes: Schritt 6, Bild 1 von 1
    • Peel the tapes off the display hinges.
  7. Dell Inspiron 11 3169 Display Assembly Replacement, Opening the Display: Schritt 7, Bild 1 von 1
    • Turn the computer over and open the display as far as possible.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  8. Dell Inspiron 11 3169 Display Assembly Replacement, Remove the Screws: Schritt 8, Bild 1 von 1
    • Place the computer face down on a flat surface.
    • Remove the screws that secure the display assembly to the palm-rest and keyboard assembly.
  9. Dell Inspiron 11 3169 Display Assembly Replacement, Lifting the Display Assembly: Schritt 9, Bild 1 von 1
    • Lift the display assembly off the palm-rest and keyboard assembly.
  10. Dell Inspiron 11 3169 Display Assembly Replacement, Placing the Display Assembly: Schritt 10, Bild 1 von 1
    • Place the display assembly on the palm-rest and keyboard assembly.
  11. Dell Inspiron 11 3169 Display Assembly Replacement, Align the Screw Holes: Schritt 11, Bild 1 von 1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest and keyboard assembly.
  12. Dell Inspiron 11 3169 Display Assembly Replacement, Replace the Screws: Schritt 12, Bild 1 von 1
    • Replace the screws that secure the display assembly to the palm-rest and keyboard assembly.
  13. Dell Inspiron 11 3169 Display Assembly Replacement, Sliding the I/O Board Cable: Schritt 13, Bild 1 von 2 Dell Inspiron 11 3169 Display Assembly Replacement, Sliding the I/O Board Cable: Schritt 13, Bild 2 von 2
    • Turn the computer over and close the display.
    • Slide the I/O-board cable into its slot on the system board and press down the latch to secure the cable.
  14. Dell Inspiron 11 3169 Display Assembly Replacement, Routing the Antenna Cable: Schritt 14, Bild 1 von 1
    • Route the antenna cable through its routing on the right speaker.
  15. Dell Inspiron 11 3169 Display Assembly Replacement, Sliding the Sensor-Board Cable: Schritt 15, Bild 1 von 2 Dell Inspiron 11 3169 Display Assembly Replacement, Sliding the Sensor-Board Cable: Schritt 15, Bild 2 von 2
    • Slide the sensor-board cable into its slot on the I/O board and press down the latch to secure the cable.
  16. Dell Inspiron 11 3169 Display Assembly Replacement, Sliding the Display Cable: Schritt 16, Bild 1 von 1
    • Slide the display cable into its slot on the system board and press down the latch to secure the cable.
  17. Dell Inspiron 11 3169 Display Assembly Replacement, Adhering the Tape: Schritt 17, Bild 1 von 1
    • Adhere the tape on the display cable.
Abschluss
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 298
