Zum Hauptinhalt wechseln
Dell Inspiron 11 3169 Display Hinges Replacement
Was du brauchst
  1. Dell Inspiron 11 3169 Display Hinges Replacement, Peel the Tapes: Schritt 1, Bild 1 von 2 Dell Inspiron 11 3169 Display Hinges Replacement, Peel the Tapes: Schritt 1, Bild 2 von 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • Peel the tapes and remove the antenna cables from the routing guide on the hinge cover.
  2. Dell Inspiron 11 3169 Display Hinges Replacement, Remove the Screws: Schritt 2, Bild 1 von 1
    • Remove the screws that secure the display hinges to the display back-cover and antenna assembly.
  3. Dell Inspiron 11 3169 Display Hinges Replacement, Lifting the Hinges: Schritt 3, Bild 1 von 2 Dell Inspiron 11 3169 Display Hinges Replacement, Lifting the Hinges: Schritt 3, Bild 2 von 2
    • Lift the display hinges off the display back-cover and antenna assembly.
  4. Dell Inspiron 11 3169 Display Hinges Replacement, Align the Screw Holes: Schritt 4, Bild 1 von 1
    • Align the screw holes on the NEW display hinges with the screw holes on the display back-cover and antenna assembly.
  5. Dell Inspiron 11 3169 Display Hinges Replacement, Replace the Screws: Schritt 5, Bild 1 von 1
    • Replace the screws that secure the display hinges to the display back-cover and antenna assembly.
  6. Dell Inspiron 11 3169 Display Hinges Replacement, Route the Antenna Cables: Schritt 6, Bild 1 von 2 Dell Inspiron 11 3169 Display Hinges Replacement, Route the Antenna Cables: Schritt 6, Bild 2 von 2
    • Route the antenna cables through the routing guide on the hinge cover and secure it in place.
Abschluss
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 202
