Zum Hauptinhalt wechseln
Dell Inspiron 11 3179 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Screw: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 11 3179 Display Assembly Replacement, Lifting the Display Cable: Schritt 2, Bild 1 von 1
    • Lift the display-cable bracket off the system board.
  3. Dell Inspiron 11 3179 Display Assembly Replacement, Peeling the Tape: Schritt 3, Bild 1 von 1
    • Peel off the tape to access the display cable.
  4. Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Display Cable: Schritt 4, Bild 1 von 2 Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Display Cable: Schritt 4, Bild 2 von 2
    • Open the latch and disconnect the display cable.
  5. Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Sensor-Board Cable: Schritt 5, Bild 1 von 2 Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Sensor-Board Cable: Schritt 5, Bild 2 von 2
    • Open the latch and disconnect the sensor-board cable from the I/O board.
  6. Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Antenna Cable: Schritt 6, Bild 1 von 2 Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Antenna Cable: Schritt 6, Bild 2 von 2
    • Remove the antenna cable from the routing guide on the right speaker.
  7. Dell Inspiron 11 3179 Display Assembly Replacement, Open the Latch: Schritt 7, Bild 1 von 1
    • Open the latch and disconnect the I/O-board cable from the system board.
  8. Dell Inspiron 11 3179 Display Assembly Replacement, Peeling the Tapes: Schritt 8, Bild 1 von 1
    • Peel the tapes off the display hinges.
  9. Dell Inspiron 11 3179 Display Assembly Replacement, Opening the Display: Schritt 9, Bild 1 von 1
    • Turn the computer over and open the display as far as possible.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  10. Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Screws: Schritt 10, Bild 1 von 1
    • Place the computer face down on a flat surface.
    • Remove the screws that secure the display assembly to the palm-rest and keyboard assembly.
  11. Dell Inspiron 11 3179 Display Assembly Replacement, Lifting the Display Assembly: Schritt 11, Bild 1 von 2 Dell Inspiron 11 3179 Display Assembly Replacement, Lifting the Display Assembly: Schritt 11, Bild 2 von 2
    • Lift the display assembly off the palm-rest and keyboard assembly.
  12. Dell Inspiron 11 3179 Display Assembly Replacement, Placing the Display Assembly: Schritt 12, Bild 1 von 1
    • Place the NEW display assembly on the palm-rest and keyboard assembly.
  13. Dell Inspiron 11 3179 Display Assembly Replacement, Align the Screw Holes: Schritt 13, Bild 1 von 1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest and keyboard assembly.
  14. Dell Inspiron 11 3179 Display Assembly Replacement, Replace the Screws: Schritt 14, Bild 1 von 1
    • Replace the screws that secure the display assembly to the palm-rest and keyboard assembly.
  15. Dell Inspiron 11 3179 Display Assembly Replacement, Sliding the I/O Board Cable: Schritt 15, Bild 1 von 1
    • Turn the computer over and close the display.
    • Slide the I/O-board cable into its slot on the system board and press down the latch to secure the cable.
  16. Dell Inspiron 11 3179 Display Assembly Replacement, Routing the Antenna Cable: Schritt 16, Bild 1 von 1
    • Route the antenna cable through its routing on the right speaker.
  17. Dell Inspiron 11 3179 Display Assembly Replacement, Sliding the Sensor-Board Cable: Schritt 17, Bild 1 von 1
    • Slide the sensor-board cable into its slot on the I/O board and press down the latch to secure the cable.
  18. Dell Inspiron 11 3179 Display Assembly Replacement, Sliding the Display Cable: Schritt 18, Bild 1 von 1
    • Slide the display cable into its slot on the system board and press down the latch to secure the cable.
  19. Dell Inspiron 11 3179 Display Assembly Replacement, Adhering the Tape: Schritt 19, Bild 1 von 1
    • Adhere the tape on the display cable.
  20. Dell Inspiron 11 3179 Display Assembly Replacement, Align the Screw Hole: Schritt 20, Bild 1 von 1
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  21. Dell Inspiron 11 3179 Display Assembly Replacement, Replace the Screw: Schritt 21, Bild 1 von 1
    • Replace the screw that secures the display-cable bracket to the system board.
Abschluss
Terrence15
79.243 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 271
